Test Question
YFD797
Member
New York
Took a test recently and found out 95% of the people answered B. But called the state and found NYS Buidling code 302.3 about non-seperated occupancy and the answer was told to me to be D. But just wanted some feedback. Here is the question...
A Fire Authority is determining the occupancy of a buidling that has mixed occupancies with no fire seperations/ Which of the following best describes how this building should be classified?
A. The building classification should be given the classification that reflects the average classification of all the occupancies.
B. The building should be given the classification of the most hazardous occupancy.
C. The building should be given the occupancy classification of the least hazardous occupancy.
D. Each occupancy in the building should be given a seperate classification.
I just can't see how if there are no fire seperations why you would not give them the highest?
If that is the entire question
Appears d would be a correct answer, because the answer does not ask you to do anything else
Question even says mixed occupancy
And to me B answer is wrong still even under non separated because you still classify each occupancy, but yes design to most stringent
I'd have to agree with cda, but what a BS question. JMHO
I would have probably got it wrong, unless I really had my game on.
FWIW, not failed a test, dozen or so certs, not bragging, just saying I can usually spot a trick question.
Sneaky.. but...
508.3 Mixed occupancies. Each portion of a building shall be individually classified in accordance with Section 302.1.
You need to classify each section as it is going to be used so you can determine OL. The building is constructed according to the requirements of the most restrictive use. In practice I think all of the students would have acted appropriately, but you have to pay attention to the wording to get the question right.
It is a good question that separates out those who know the code and those who shoot from the hip.
The best distractors are those which people jump to intuitively without carefully reading the question.
Not only is the answer correct, it is a great test question.
The question is about occupancy classification not height and area limitations.
If a person does not have the level of reading comprehension necessary to select the correct answer, they have no business interpreting the building code because correctly interpreting the code requires attention to detail, not leaping to conclusions based on the first idea which pops into one's head.
The code isn't written at a sixth grade level, and if people who can't read above it are prevented from becoming code officials that is a good thing.
Agree it is a good question and the clue to the answer was in the question. You should have gone to Mixed Occupancies and there was the answer as TimNY pointed out
Brudgers;;;;
Using crayon to write resignation letter, only at 5th 1/2 grade reading level
You guys are great. I have another question but it is not code related it is a Fire Training question that all of us are fighting over. Do you guys mind if I post it for you to look at?
Wow glad I picked out the section that mattered like MT said and went to 508. I think it's a pretty good question and remember in taking code related tests, don't read into it and find the areas of thew question that matter. Excellent point MT!
Which of the following is the mistake often made by inexperienced officers when instructing new Firefighters.
A. Oversimplifying the material to the extent that the Firefighters lose interest.
B. Covering exceptions exclusively instead of the routine work.
C. Assuming Firefighters know more than they actually do.
D. Neglecting to teach broad principles over which Firefighters may generalize.
Its a choice between 2 of them. And I don't like the word Assume, because you know what that does?
YFD797 said:
I went with the physical dooing. I dont like the assuming. Although it's not bad.
And that's why it's a mistake ;) You shouldn't assume; if you assumed your firefighters knew something, you made a mistake, and that would be a correct answer.. imho.
Well, FWIW, and I responded to quickly on the last one. I know you classify the occupancies, not the building. Knee jerk reaction to the question, I do know better. Oh well, mia culpa. The second question, I would have to agree with TimNY's reasoning.
