Pcinspector1 said:Bob, I would have a concern about attaching vinyl siding over it with the siding nail catching a stud and being nailed at 16" o/c. I think if you check your siding specs you would need additional nails that would fall between the studs which would only enter the Thermo-ply. Not much to nail too.
There's also a Blue structural panel available.
pc1
Strong walls have been a good solution for us to be able to comply with the ever increasing structural requirements imposed from the building codes.MASSDRIVER said:Can you guys please make it illegal?We can lump it in there with other crap Baby Jesus hates, like vinyl windows, vinyl siding, expanding foam, and strong walls. I don't even want to get started on styrofoam backed stucco.
Brent.
Amongst other reasons.Rio said:Strong walls have been a good solution for us to be able to comply with the ever increasing structural requirements imposed from the building codes. Ah, the Strong Wall. Sometimes Simpson makes good products that save time, ease installation, etc. Sometimes, they invent a product then make sure there is a need for it. I think that is the Strong Wall. It is diabolical in it's ability to slow down a job, add costs, make every other job within 5 feet of it twice as difficult to do, and make money for Simpson. It DRASTICALLY slows down the framing process, limits your ability to do electrical and plumbing, is encased in metal skeletal parts thus making drywall difficult, as well as trim, and is rarely dimensionally correct.
Vinyl windows, good ones, seem to work well, do a better job of not transmitting heat (or cold), once again making it easier to comply with ever more stringent code requirements and require a lot less maintenance than other alternatives; They've become ubiquitous in houses that aren't high end. I'm curious what you don't like about them?
It is plastic molded into a window shape. They are rarely, if ever, dimensionally correct, square, or strait. The vinyl components have to be huge to have a minimum of structural integrity, so you get less window, but more plastic. The material has so much thermal movement it becomes weak from movement and connections fail. When they heat up they operate like crap. They will rub one day, but not the next. They will latch in the morning, but not the afternoon. Some manufacturers make a product that is useable, but nobody buys those.
Vinyl siding, while esthetically not so appealing, does work and is an affordable alternative to stucco for a low maintenance surface. What I found interesting vis a vis vinyl siding was the last time we had to use it to match an existing finish on a house that was in the urban/wildfire interface that it was rated pretty well regarding that issue...... go figure. Is it for the looks that you don't like vinyl or is there another reason?
Because vinyl siding is a product specifically designed to cover up, mask, and promote denial that there may be a material failure or maintenance issue that needs to be resolved. Used on new construction it is probably fine. Why you would use it is a mystery to me as I think it looks craptastic, but that's just me. Let me turn it around on you just for fun. When you come upon a house sided in vinyl, is your first thought "Very well constructed house with no issues", or "wonder what's hiding behind that plastic". Thought so Lastly, Vinyl-siding-installation-world is a place populated by hucksters, miscreants, and Sears.
In the 60s and 70s I was a member of the NAHB, during a dinner an executive from national gave a talk during which he said that we built too well, we should take a page from the car makers book and build homes that deteriorate so we could repeatedly sell people new homes, I was so disgusted that I switched from the NAHB to the AGC. At the time I had to wonder how they were going to do this, codes and all, it came about through the codes mandating the use of products that seal up walls like plywood sheathing to trap moisture in the walls with insulation in the walls to hold it while the walls rot away.Remodeling Magazine said:— and as JCHS’ Kermit Baker likes to point out, builders put up a lot of lousy homes during the 1970s.¹
There are better products like Hardy Frames, a former carpenter built this home, the Simpson products cost over $30,000, the labor to install them had to cost double that, and he still had $30,000 worth of red iron moment frames. seeing the moment frames in this addition, I've switched to all steel framesView attachment 833MASS said:Ah, the Strong Wall. Sometimes Simpson makes good products that save time, ease installation, etc. Sometimes, they invent a product then make sure there is a need for it. I think that is the Strong Wall. It is diabolical in it's ability to slow down a job, add costs, make every other job within 5 feet of it twice as difficult to do, and make money for Simpson. It DRASTICALLY slows down the framing process, limits your ability to do electrical and plumbing, is encased in metal skeletal parts thus making drywall difficult, as well as trim, and is rarely dimensionally correct.
Most PVC products are crap for the lower socioeconomic classes that don't know the difference, on the other hand the tree huger variety of Greenie has made good wood for wood windows unavailable, many cities in Germany have banned PVC so the German industry has come up with uPVC, I am importing and using uPVC windows that are now being fabricated in Canada..¹ Why Lousy Homes Mean Great Prospects for You - Remodeling Trends, Construction Management, Demographics, Remodeling, Housing Trends, Software, Aging In Place - Remodeling MagazineView attachment 834MASS said:It is plastic molded into a window shape. They are rarely, if ever, dimensionally correct, square, or strait. The vinyl components have to be huge to have a minimum of structural integrity, so you get less window, but more plastic. The material has so much thermal movement it becomes weak from movement and connections fail. When they heat up they operate like crap. They will rub one day, but not the next. They will latch in the morning, but not the afternoon. Some manufacturers make a product that is useable, but nobody buys those.
¹ City of San Leandro - Building CodesCity of San Leandro said:It should be noted that the above codes have been modified by the State of California and the City of San Leandro to include various additional requirements based on local conditions. For instance, the Plumbing Code has been amended to prohibit the use of plastic pipe (i.e. ABS and PVC) within the drain, waste and vent system of a building. And the structural provisions of the Building Code have been modified to address earthquake design standards.¹
Because it's cheap crap, permits for a new home here run about 7 years on average, so we try to find old houses and remodel them in a way that nobody knows that they were remodeled. In the home I pictured above the field inspector found one thing in his foundation inspection, he could see a piece of white PVC in the corner of a footing, I told him it was an old abandoned lawn sprinkler line, he said to get it out of there, he didn't allow plastic in his jurisdiction, I had a man remove it as we finished our walk around. At frame inspection he looked up at the roof framing and asked me to explain my ventilation path, I showed him the $7,000 worth of fire-dampened soffit and ridge vents, he said fine but you aren't going to try to put that damn plastic spray foam in here? I told him no that it would be fiberglass, he said "Good, we allowed it in one house and it's actually raining indoors from all the condensation, we don't allow it anymore.".ICE said:Conarb,Do you know why the city of San Leandro has banned ABS and PVC for use in DWV?
It is simplistic to relegate an ICC ES to the status of "opinion". Much effort and consideration is given to an ICC ES. If both a doctor and a bag boy have an opinion on why your head is twice normal size. Which opinion carries the most weight?Mark K said:An ICC-ES evaluation report for a product that is not addressed in the code is only an opinion and you have no obligation to allow its use.
The warranty is not a building dept. concern and to determine the lifespan of a product from the time frame of the warranty is not appropriate. There are asphalt shingles that have a lifetime warranty.the warranty
That's the building department's problem, not the product's.cannot be inspected, do to time constraints
Write a correction.not seen one that was being done according to the "manufacturer's instructions"
Ditto.It is void if the product is exposed to "the elements" for more than 60 days; and I have seen many of these surcumstances; and "excessive"? ultra-violet exposure.
Me too but that's not sufficient reason to reject the product.the idea of paper being acceptable is rediculous in my opinion
