I feel like Im hogging up a few threads here and there... Its tough for me to not talk about this stuff,
as I have been passionate about it since 2006.. So for that I apologize!
Absolutely the best way to manage insulation in real cold climates, Id guess building science wise, its probably the best way in any climate.
If anyone is truly interested in architectural details, a resource worth its weight in gold is Joes book Building for cold climates and his website,
buildingscience .com
I have been involved with a few Passive houses here on long Island and one where that type of hot roof was done...
Got tricky at the fascia and soffit though. They ran continuous insulation down the fascia, back under the soffit to meet the exterior insulation under the siding.
Going even further than that, there is something called a cold roof where a typical hot roof with exterior continuous insulation is built but over that is another roof with an air space between the two. If I remember correctly, the idea is that with heavy snow loads, and the associated R value of snow, the melting point of snow could be reached at the roof surface, so adding an air space prevents any heat from touching the surface that the snow sits on. Exterior vented roof deck ??
If you think about it, its kind of like a wall with framing, exterior insulation, 1x2 or something similar for the air gap, and siding but in this case you rotate the wall to the pitch of a roof and swap cladding for roofing.
Good stuff!
