Threaded trap in concealed location
Can you install a threaded style p trap in a concealed location such as for a bath or shower on the 2nd floor where it will be drywalled below with no access?
State your case, IPC or IRC please. Give code references if you answer please.
jar546 said:
Can you install a threaded style p trap in a concealed location such as for a bath or shower on the 2nd floor where it will be drywalled below with no access?State your case, IPC or IRC please. Give code references if you answer please.
IPC 405.8
IRC 3201.1
Non compliant unless access panel is provided.
