MEP
I have a project that is proposing a duplex with (2) attached ADU's, one on each side. There will be a property line separating the structure into (2) halfplexes, each with an ADU. Since there are (4) attached units, would this be considered a townhouse by definition? Or could it be reviewed as a two-family dwelling (with an ADU)?
"[RB] TOWNHOUSE. A single-family dwelling unit constructed in a group of three or more attached units in which each unit extends from foundation to roof and with a yard or public way on not less than two sides."
Going further down the rabbit hole, would it also be considered a covered multifamily dwelling?
COVERED MULTIFAMILY DWELLINGS. [HCD 1-AC] "Covered multifamily dwellings" means either of the following:
I understand it is CA's intention to encourage ADUs, so I am not sure if the accessory unit would count toward the townhome definition. But, it IS still a unit. Main considerations are structural independence and fire separation. I am still investigating the ownership structure, but any input would be helpful.
- Buildings that consist of at least four condominium dwelling units or at least three apartment dwelling units if the buildings have at least one elevator.
- The ground floor dwelling units in buildings that consist of at least four condominium dwelling units or at least three apartment dwelling units if the building does not have an elevator.
