Project is a row of 6 townhomes - 2015 IRC applies.
I'm using Common walls between units with a 2 hour rating. Per R302.2.2 and R302.2.3, the rating is continued tight to the underside of the roof sheathing.
As I read the code, there is therefore no requirement for a parapet extending through the deck.
I see in R302.2.4 where you can eliminate a required parapet by sheathing the underside of the deck in Type X for 4' on either side of the common wall.
What I don't see in the code is language that defines when a parapet is required. R302.2.4 is full of language that defines the rules for parapets when they are required, but what triggers them to be required in the first place.
