Transformer Supply Side Bonding Jumper
If you had a 480/277v to 208/120v wye-type transformer where the primary side of the transformer (xfmr) was fed from an MDP after the service, what table would you use to size the supply-side bonding jumper on the secondary side of the transformer if the xfmr was supplying power to a panelboard for an office?
Remember that the primary side feeding the transformer from the MDP would be sized per Table 250.122 as it is an equipment grounding conductor.
But I don't see any difference between table 250.102(C)(1) and table 250.66 Grounding Electrode Conductor for Alternating-Current System except in the notes.
