FIRE SEPARATION DISTANCE. The distance measured
from the building face to one of the following:
1. To the closest interior lot line; or
2. To the centerline of a street, an alley or public way; or
3. To an imaginary line between two buildings on the lot.
The distance shall be measured at a right angle from the
face of the wall.
R302.1 Exterior walls. Construction, projections, openings
and penetrations of exterior walls of dwellings and accessory
buildings shall comply with Table R302.1(1); or dwellings
equipped throughout with an automatic sprinkler system
installed in accordance with Section P2904 shall comply
with Table R302.1(2).
TABLE R302.1 EXTERIOR WALLS
EXTERIOR WALL ELEMENT | MINIMUM
FIRE-RESISTANCE RATING | MINIMUM FIRE SEPARATION DISTANCE | |
Walls | (Fire-resistance rated) | 1 hour-tested in accordance with ASTM E 119 or UL 263 with exposure from both side | < 5 feet |
"The exterior rated walls should be tested in accordance with either ASTM E 199 or UL 263. This is not intended to limit fire-resistance-rated assemblies solely to the test criteria contained in these standards. Section R104.11 still allows the building official to approve alternative fire-resistance methodologies, such as those described in Section 703.3 of the IBC. This would still allow a builder to use acceptable engineering analysis, calculations in accordance with Section 721 of the IBC or prescriptive assemblies permitted by Section 720 of the IBC as alternatives tot he standards contained within the code."
R104.11 Alternative materials, design and methods of construction and equipment. The provisions of this code are not intended to prevent the installation of any material or to prohibit any design or method of construction not specifically prescribed by this code, provided that any such alternative has been
approved. An alternative material, design or method of construction shall be
approved where the
building official finds that the proposed design is satisfactory and complies with the intent of the provisions of this code, and that the material, method or work offered is, for the purpose intended, at least the equivalent of that prescribed in this code. Compliance with the specific performance-based provisions of the International Codes in lieu of specific requirements of this code shall also be permitted as an alternate.
