Two way communication system VS Emergency Radio Coverage System
suoLL RBM
Phoenix, AZ
What is the difference between Two-Way communication system and Emergency Coverage System? If I provide either one or another is that suffice to comply Code for a 4-story multifamily complex? Do I need to provide both systems?
They are two completely different systems.
Two-way communication devices connect people located in areas of refuge or elevator lobbies to a central control point or fire command center.
The emergency responder communication coverage system boosts signal coverage within a building so that emergency responders can communicate with each other.
Communication: Occupant to emergency responder, usually via a hardwired intercom fixed on a wall. For example, when the elevator is inoperable during a fire, the occupant can call down to the fire command center and get instructions on how to prepare for rescue and safety.
Communication: Emergency responder to other emergency responders via each person's municipal "walkie talkie" 2-way radio system. I typically see this at subterranean parking garages or other concrete structures where radio reception is poor. The booster(s), if needed, should provide 2-way radio signal coverage from any point within the building.
