I doubt that you will find that there is a "UL classified block" What I believe is that you will find that the assembly requires block of a certain thickness and having a certain weight (lightweight , normal) and possibly a "Type" classification that is defined in a ASTM standard. Read the description of the assembly.The above listed characteristics should be listed in the permit documents and the masonry special inspector should verify compliance with the permit documents. If special inspection is not called for there is no formal requirement although I would expect that if we are talking about a significant building that special inspection would be required.
