klarenbeek
Silver Member
If you've determined a Type I hood is not needed, the next step would be going to a Type II for the heat and steam. If you are under the IMC, 507.3 for Type II hoods actually allows for not having a hood over electric appliances if the heat and steam load is accounted for in the HVAC system design and 100 square feet is added to square footage calculations for general ventilation requirements for every appliance not under a hood. Gas appliances will always require a hood to extract products of combustion out of the space. Electric appliances that would normally only need a Type II hood, no hood required.
