mtlogcabin
I have an existing 400 sq ft walk in cooler located inside a 1,200 sq ft V-B building used to store seeds. They want to add 240 sq ft to the existing walkin cooler bringing the sq ft of the cooler to 640 sq ft. The cooler walls are 2 x 6 with 4 inches of foam and 1/2" OSB on both sides(similar to a SIPS panel. Question does the 640 sq ft walkin cooler need to be sprinklered or is the 1/2" OSB thermal barrier sufficient?
2009 IBC
2603.4.1.2 Cooler and freezer walls.
Foam plastic installed in a maximum thickness of 10 inches (254 mm) in cooler and freezer walls shall:
1. Have a flame spread index of 25 or less and a smoke-developed index of not more than 450, where tested in a minimum 4 inch (102 mm) thickness. Compliant
2. Have flash ignition and self-ignition temperatures of not less than 600°F and 800°F (316°C and 427°C), respectively. Compliant
3. Have a covering of not less than 0.032-inch (0.8 mm) aluminum or corrosion-resistant steel having a base metal thickness not less than 0.0160 inch (0.4 mm) at any point. Installed over the OSB, Compliant
4. Be protected by an automatic sprinkler system in accordance with Section 903.3.1.1. Where the cooler or freezer is within a building, both the cooler or freezer and that part of the building in which it is located shall be sprinklered. Non-Compliant
2603.4.1.3 Walk-in coolers.
In nonsprinklered buildings, foam plastic having a thickness that does not exceed 4 inches (102 mm) and a maximum flame spread index of 75 is permitted in walk-in coolers or freezer units where the aggregate floor area does not exceed 400 square feet (37 m2) and the foam plastic is covered by a metal facing not less than 0.032-inch-thick (0.81 mm) aluminum or corrosion-resistant steel having a minimum base metal thickness of 0.016 inch (0.41 mm). A thickness of up to 10 inches (254 mm) is permitted where protected by a thermal bar Exceeds the 400 sq ft limitation
2009 IBC
