Karencita42
Good morning all,
I have a 30 gallon water heater and will be replacing it with a tankless water heater. The 30 gallon water heater has two grounds attached to the inlet copper pipe. The unit itself is also grounded via the ground running from the breaker to the tank with the two other hot wires.
What do I do with the grounds attached to the copper water pipe? Do I need to reground those or just disreagard as the 8 gauge wire has a ground already.
