forensics
Bronze Member
Here we go again.....
A local small water system here in South Carolina has ruled that they will not allow a homeowner of a three story beachfront home to combine the domestic water system and the residential sprinkler in a single tap.
The Board of Water would not respond to a request for the logic behind their decision.
Testimony was presented that included the following points;
1) The sprinkler system when connected to the single tap was valued at about $1.90 PSF (heated) and the cost was impacted by more than $6,000 to bring the cost PSF to $2.80
2) The necessity to provide a DC BFP added an additional cost per year (for testing and maintenance) to almost as much as the entire system when considered as impact to the mortgage portion of the house payments
3) The "stand alone" system required annual testing of the system because the domestic water could not be considered to "prove" the system on a daily basis
4) The comparision was made between the impact when thousands of gallons of water are pumped onto a fire as compared to the one hundred of so gallons of water discharged on the fire in its incepient stage
5) The runoff and contamination of the groundwater and the open water bodies from the large scale water flow in a fire
6) The fire water was unmetered as compared to the multipurpose system which utilized the metered connection
7) The homeowner was taking the initiative to provide his first tier of fire protection and therefore lowering the town's exposure and risk
8) Both the homeowner and the firefighters would enjoy a significant reduction in the life safety equation when the sprinklers were employed
Without regard to these issues they elected to force the owner to go the more expensive route even though they were well informed as to the benefits of residential multipurpose sprinkler systems.
Once again here is a prime example of the very agency that is charged with serving and protecting the public placing impediments on the widespread implemintation of these proven life saving systems
----SHEESH
So what is your water departments position on this issue???
----SHEESH
