Meadowbend99
I have a project that needs to comply with 2012 IBC. There is an existing Manor (Super large house) that my client is purchasing and turning into a wedding venue. The property is 25 acres with several smaller houses along with the main manor house. They are not looking to make significant changes to the existing properties except adding ramps for entry.
They are adding a metal building ballroom behind the house and attached to the main manor with an upstairs covered breezeway connecting the existing to the new. They want a really nice stairway leading from the upstairs to the middle of the ballroom space to use as a bride and groom entry. It is not an interior stair leading to the exterior, so it cannot be used as an exit stair. We are adding a 2nd level to the ballroom with an occupant load over 100 that this stair comes off from. If you're up on the 2nd level you have the ability to exit to the main manor as a horizontal exit. I'm trying to see if there is a way to not add another stair from that level leading to the exterior. The ballroom is only 2 levels, as is the Manor house. Could it be considered exiting through an intervening space if they use the central stairs and go from ballroom space to ballroom space and exit through a first floor exterior door?
They are also adding a Chapel to the property. Ceremonies are only for wedding guests and will only last 30 min. to 1 hr. The Chapel is approximately 160' from the entry to the Ballroom and will hold 300 guests. Per code it would require 2 men's toilets and 5 women's. Since the spaces are so close together and the purpose of the Chapel is on a short time frame, is it possible to reduce that number in the Chapel. Could they omit the drinking fountain since they are so close to the dining rooms? Or omit the service sink and utilize the sink at the Ballroom?
