That's incorrect, corner Bars are bent Bars that are used to connect rebar is around corners. These are straight Reentry Bars.Corner bars. Everything else is wrong.
And it looks like they are a little close to the column on the lower right corner.The arrangement of bars in the picture ignores the holes in the slab due to the sleeves shown.
Thanks for the Sunday morning trolling Mark. While I understand that construction drawings should ideally be clear and comprehensive, common terminology is critical for effective communication among all parties involved. This includes architects, engineers, and yes, building inspectors. Misinterpretation of drawings can lead to expensive mistakes, safety risks, and delays. Precise terminology is not mere pedantry; it's a cornerstone of professional collaboration and public safety. Without agreed-upon nomenclature, we risk undermining the very systems and standards that ensure the structural integrity and safety of a building. It is not just about 'calling them anything'; it's about ensuring that everyone—regardless of their professional background—understands what is expected and requiredIf the construction drawings are clear as to size length and location you do not need to call them anything.
According to Mark K, you don't have to call them 'tilt-up' walls or 'pan decks' as long as they are just designed, we just build them and inspect them to the drawings like the simps we are, and don't worry about what they are called. We are there to do, not talk or ask questions while the almighty engineer wields his power of design. I believe it is OK to point and grunt, however.I refer to them as “diagonal bars”. Openings in tilt-up walls have them. I haven’t been involved with many pan decks but they make sense.
Why do you hate engineers?According to Mark K, you don't have to call them 'tilt-up' walls or 'pan decks' as long as they are just designed, we just build them and inspect them to the drawings like the simps we are, and don't worry about what they are called. We are there to do, not talk or ask questions while the almighty engineer wields his power of design. I believe it is OK to point and grunt, however.
Mark, Mark, Mark. Why do you think that I hate engineers? There is no shortage of members who are aware of your open disdain towards building officials and building departments. Yes, engineers take on more liability than the building department, but then again, you are compensated for it, much more than what employees of building departments make. You see, it is all relevant. You can always choose to work for a building department and limit your liability. You have the option to bend the ear of State Legislators and work towards some building department reform. You have options, Mark.Why do you hate engineers?
I have pointed out problems with building departments and plan checkers but that does not mean that I have disdain for all building departments and building officials. Disdain as well as respect must be earned. Most individuals fall in neither of these extremes.Mark, Mark, Mark. Why do you think that I hate engineers? There is no shortage of members who are aware of your open disdain towards building officials and building departments. Yes, engineers take on more liability than the building department, but then again, you are compensated for it, much more than what employees of building departments make. You see, it is all relevant. You can always choose to work for a building department and limit your liability. You have the option to bend the ear of State Legislators and work towards some building department reform. You have options, Mark.
I don't hate engineers. I have many friends and acquaintances who are engineers. Civil, structural, electrical, etc. Hell, even my nephew is a mechanical engineer (We Are Penn State). I enjoy a very good professional relationship with engineers and architects. A relationship based on mutual respect. Something you lack as an engineer.
That is a MAJOR problem that should not happen. The two states I worked in have a system to handle situations like that with more than one option in that system. No one should ever say the proverbial "Do as I say" and get away with it.I recall one atypical situation where I politely asked what was the code requirement he was enforcing and the response was that there was no code requirement but that we would not get a permit if the change was not made. This was a clear case of extorsion.
It happens every day. We decide if it costs more to comply or fight. Most often the delay alone from the fight costs more than the imaginary code from the B.O.That is a MAJOR problem that should not happen. The two states I worked in have a system to handle situations like that with more than one option in that system. No one should ever say the proverbial "Do as I say" and get away with it.
