What Do You Call This Type of Construction in Your Area?
Is the variety where the pieces are cast at a precaster and shipped to the site differently named than where the pieces are cast on site.and tilted up?
Based on the second photo from the top left, I took it to be the type of construction where the wall panels are cast on-site after the floor slab has been poured, then the walls are simply tilted up and dropped into position.
Tilt-up construction. It is a form of precasting completed on site. The building’s slab-on-grade floor or a separate casting slab is used to form one side of the wall (typically the back side).
If the slab-on-grade floor is used for casting, the panels are then tilted up into position where they are located and anchored to the footing and to the adjacent panels. If using a separate casting slab, the panels are lifted and carried to the area of the building where they will be installed.
Tilt-up. (or Type I/II given you indicated Type of Construction ;))
It could be any construction type, really, depending on the specified fire resistance.
You could have a concrete building with metal interior stud partitions within the allowable height and area for a Type VB building without requiring it to be a Type I or II building.
I know... was just being smart.
