LGreene
Sometimes I have a hard time deciding whether a door is "readily distinguishable from the adjacent construction and finishes." What do you all think about this door: http://idighardware.com/2010/11/out-to-lunch/
That brings up another question...I have architects designing frames that move the door so it is flush with the push side of the frame. So far I have not had any code officials object, but I do think that makes the door less obvious.Yikes: "The door is inset by a few inches, so even thought he racing stripe goes across the frame, it is still obvious as to the extent of the door leaf."
You're right, but our accessibility standard doesn't require the 10" bottom rail (yet).Mark Handler: "The glass door does not appear to have a 10" high kick at the bottom."
Do you not enforce ICC/ANSI A117.1-2003?LGreene said:You're right, but our accessibility standard doesn't require the 10" bottom rail (yet).
No, we have a state accessibility standard - 521 CMR. My office covers the 6 New England states and several of the others use A117.1 but not Massachusetts. I have a post about the flush bottom rail requirement here: http://idighardware.com/2009/03/flush-bottom-rail/Mark Handler: "Do you not enforce ICC/ANSI A117.1-2003?"
Signage isn't considered part of the door hardware so it's not my area of expertise, but I tried looking in our state accessibility standard and didn't find much about braille signage. Maybe I'm just missing it.RJJ: How about the braille exit sign for the rear door? And the front door?
Here's that section with the commentary. It seems like this would apply to areas of refuge and exterior areas for assisted rescue only, no?RJJ: I was referring to 2009 IBC section 1007.9 last part.
No go. The graphic Conceals the fact that it is a door/exit. With the power out, at night, with no backlighting.LGreene said:I went back to the restaurant and took a picture of the door so you could see the treatment on the glass. I think it's similar to the advertisements on buses, and I bet we'll be seeing more of this on doors.
