Darren Emery
I'd like to discuss a purely hypothetical situation. Nothing like this would ever happen. Right?
Type 1 kitchen hood is designed by PE, everything on paper looks great. Resturant owner buys different equipment, and work in the field stops when inspector realizes nothing matches plans.
Signficant change to make up air location and duct work. Original back shelf plenum (6" x 72") gets redesigned and choked downt to 6" x 12". PE puts a note on the plans to increase the speed on the MAU fan to compensate for the restriction.
Mechanical contractor responsible for the install balks - he knows this thing won't supply correct cfm due to the choke point, and very likely will not pass balance test or perform well.
As an inspector, what do you do? Approve because it's as designed on plans...or tell them all to go back to the drawing board and come up with a better solution. Or something in between?
