If this is true I wonder how many legs can be on the sides or if there is a minimum space required under the bed.I believe it's open under the bed incase they need some kind of left that would have room for the feet or like when your in a hospital bed the portable tray that goes over your bed has feet with casters on it?
Only my speculation.
You get the gold star...And Sifu with the assist!I believe it's open under the bed incase they need some kind of left that would have room for the feet or like when your in a hospital bed the portable tray that goes over your bed has feet with casters on it?
Here in California, we don't normally deal with ANSI 117.1, so I have to ask: under what legal scenario can building code prescribe non-building furniture?
This is for an accessible apartment in a R1 building.I believe it's open under the bed incase they need some kind of left that would have room for the feet or like when your in a hospital bed the portable tray that goes over your bed has feet with casters on it?
The same legal scenario that allows the building code to regulate the arc of the water at a water fountain.Here in California, we don't normally deal with ANSI 117.1, so I have to ask: under what legal scenario can building code prescribe non-building furniture?
Except that post #1 stated that at least one bed "shall be provided" at accessible units. Assuming it was quoted correctly, that is a scoping statement, and it applies to units required to be accessible.I would like to make the point that is the case when a bed or beds are installed. Nothing requires a bed. This is a requirement for the occupant or owner for compliance. I don't often do finals when furniture is installed already unless it is a partial remodel.
Paul, in addition to vertical grab bars and increased maneuvering spaces, 2017 ANSI 117.1 moved the accessible dwelling unit requirements away from ADAS 809.1-4, and instead created a brand new chapter 11 just for dwelling units. In this chapter they added the requirement for an accessible dwelling unit to provide an open bed frame and a mattress.When you enforce ANSI A117.1 you are basically enforcing ADA, because ADA Standards for Accessible Design and ANSI A117.1 are basically the same! The technical standards were the same until 2017 when ANSI A117.1 added vertical grab bars and increased some maneuvering spaces.
Is this the part where I say that I "Stand corrected?"Except that post #1 stated that at least one bed "shall be provided" at accessible units. Assuming it was quoted correctly, that is a scoping statement, and it applies to units required to be accessible.
