whats your take on this Code difference
linnrg
Sawhorse
Sterling Alaska
BTW I am under the UPC and I do enforce the installation of the air gap.
UPC World
“807.3 Domestic Dishwashing Machine. No domestic dishwashing machine shall be directly connected to a drainage system or food waste disposer without the use of an approved dishwasher airgap fitting on the discharge side of the dishwasher machine. Listed air gaps shall be installed with the flood-level (FL) marking at or above the flood level of the sink or drainboard, whichever is higher.”
IRC World (2018)
P2717 Dishwashing Machines
P2717.1 Protection of water supply. The water supply to a
dishwasher shall be protected against backflow by an air gap
complying with ASME A112.1.3 or A112.1.2 that is installed
integrally within the machine or a backflow preventer in
accordance with Section P2902.
P2717.2 Sink and dishwasher. The combined discharge
from a dishwasher and a one- or two-compartment sink, with
or without a food-waste disposer, shall be served by a trap of
not less than 11/2 inches (38 mm) in outside diameter. The
dishwasher discharge pipe or tubing shall rise to the underside
of the counter and be fastened or otherwise held in that
position before connecting to the head of the food-waste disposer
or to a wye fitting in the sink tailpiece.
In my mind, the UPC wants an air gap in the sanitary line. The IRC wants an air gap or backflow preventer in the potable water line but has no requirement for an air gap in the sanitary line.
Click here for an image.
