When Blueprints Were Blue: How Construction Evolved Through Ink, Chemistry, and Control
Before PDFs, digital submittals, and cloud-based plan portals, we had real blueprints—chemically treated sheets that turned deep blue with white lines. Anyone who’s been in this business long enough remembers the smell of ammonia from a diazo machine or the feel of those oversized, curled-up rolls. But what most people don’t realize is that blueprints weren’t just about showing what to build; they were created to control what was being built and to keep everyone honest.
The Early Days: Linen, Ink, and Creative Control​
In the 19th and early 20th centuries, architects and engineers drafted plans by hand using India ink on linen or vellum. These were durable materials that held up better than paper. But they were one-offs. The “original” was it. If someone wanted to build off that, they had to either trace it or redraw it entirely.
And that’s where things went sideways.
Before blueprints became the standard, the architect often held all the cards. Daniel Burnham, the renowned Chicago architect behind the 1893 World’s Columbian Exposition, was known for quietly editing other architects’ plans. If he didn’t like a design element, he’d take the drawing, make changes to it on his own time, and then slip it back into the process. No warning, no sign-off, and no real way to track it. This wasn’t unique to Burnham; it was the norm. If you had the only copy, you controlled the project.
Cyanotype Changes Everything​
Then came the blueprint. The cyanotype process was developed in the 1840s and adapted for architectural use in the decades that followed. Drawings on translucent linen or tracing cloth could be placed over light-sensitive paper and exposed to sunlight. Where the light passed through, it triggered a chemical reaction that turned the sheet blue. Where the ink blocked the light, white lines remained. The result was a cheap, reliable duplicate that preserved every detail of the original.
Now contractors, trades, inspectors, and builders could all work from the same document. It created accountability. You could roll into court with a print and prove exactly what was supposed to be built. Changes had to be reissued. Revisions had to be tracked. Blueprints brought order to the chaos.
From Artist to Coordinator​
Before blueprints, the architect was often seen as more of a visionary—a creative mind with a pencil and a sketchpad. But when blueprints took over, the role evolved. Now the architect wasn’t just designing; they were coordinating. They had to produce clear, detailed documents that electricians, masons, and framers could actually build from. The drawing set became a legal record, not just an artistic suggestion.
Compare the past to today and you’ll see just how far things have gone. The Empire State Building was constructed in 1930 and only required about 100 sheets of drawings. Today, that same structure would likely require thousands of sheets, broken into disciplines, with revision logs, cross-references, and callouts on every page. The expectations shifted, and so did the responsibility.
Sears and the Democratization of Construction​
Blueprints didn’t just change commercial buildings; they helped bring construction to the everyday American. In 1908, Sears, Roebuck & Co. launched its Modern Homes program. You could order a house from the Sears catalog, and a boxcar would show up with all the precut lumber, windows, nails, doors, and a complete set of blueprints. That’s how a regular person could build a home, because the plans told them exactly how to do it.
Over the next three decades, Sears offered over 370 different designs and shipped out more than 70,000 homes. The blueprints were critical. They standardized the process, ensured quality, and eliminated guesswork. If Sears could put together a house kit that worked across the country, it was because the drawings were clear enough for anyone to follow.
Why This Still Matters​
Even though we don’t use chemically developed blueprints anymore, the principles behind them haven’t changed. We still need control. We still need coordination. We still need to know that what’s on the drawing is what’s in the field. Whether it’s a stamped PDF or a full-size plot, the purpose is the same: clarity, accountability, and a shared understanding of what is being built.
So the next time someone tosses around the word “blueprint” without thinking, remember this: that word came from a time when drawings were burned into paper with sunlight and washed in water. When one drawing could make or break a project. And when printing a second copy meant locking in the truth for everyone to see.
The first architectural firm I worked for (right out of high school), I ran prints through an ammonia machine for three days straight. Sometimes I can still smell the ammonia - though there isn't any around!
At some point the chemical process went to the reverse - the UV light in the machine would burn off the coating, leaving the yellow coating where the pencil/ink lines had been, then running it through the ammonia would turn the lines blue. What many people still call "blueprints" are really "bluelines"; with the sepia tones we also had "brownlines" and also "blacklines" which were used for rendering.
First firm I worked for had a dedicated staff person just for the blue line machine. He claimed to never have a stuffy nose in all the years he’d worked in that room… thought this was a good thing.
I remember those, too. Diazo printing.
The paper came in heavy, black plastic packages and had to be stored in the plastic to avoid exposure to light before use.
First thing we would do when we opened a new package was to slip a note in about 10 sheets before the bottom: “ORDER MORE 30x42 BLUELINE”.
Leaving the next user without paper was more rude than stranding someone with an empty roll in the restroom.
Please elaborate.
A few of the more obvious misrepresentations:
  1. Blueprints did not change what buildings looked like or the way architects envisioned buildings
  2. Hatch patterns most certainly do resemble real-world materials. They are not perfect, but we choose hatch patterns specifically because they resemble the appearance of the materials they are intended to represent.
  3. Buildings didn't become simpler/plainer in appearance around 1900 as a result of blueprinting. They became plainer because plainer was easier, faster, and cheaper to construct.
  4. Architectural expression was not constrained by the medium of blueprinting. The Empire State Building was built from blueprints. H.H. Richardon's Romanesque libraries were very detailed, and were built from blueprints.
  5. The need for more and more pages of drawings was not a result of blueprinting, but was a result of buildings becoming more complex, and the construction contracting process becoming more technical and legalistic.
  1. Let’s clear something up. (or not) None of what I wrote claimed that blueprints changed the way buildings looked. What they changed was how the process was controlled. Before blueprints, the architect had all the power. Once multiple copies could be made and distributed, the power shifted. Now, everyone was working off the same set, and that forced accountability. Contractors could push back. Inspectors had something to reference. Owners could catch changes. That’s the point.
  2. On the hatch pattern comment, let’s be honest. Hatch patterns don’t “resemble” anything. They are symbolic. The brick hatch doesn’t look like brick. The stone hatch doesn’t look like stone. They just tell you what the material is supposed to be. If people think hatch patterns are an artistic representation of real materials, they’re confusing technical drafting with graphic design.
  3. As for the claim that architecture didn’t get simpler because of blueprints, I disagree. Early blueprinting processes were limited. Fine lines, ornate detail, light shading—they didn’t always reproduce well. That meant architects started designing within those constraints. Not because they lacked creativity, but because if the drawing couldn’t survive reproduction, it wouldn’t make it into the field. Function-shaped form. That’s not a theory. That’s how architects adapted to the tools they had.
  4. The Empire State Building proves my point, not theirs. That entire building was constructed with around 100 sheets of plans. Try building a modern commercial job with those few sheets today. You’ll never get it through permitting, inspections, or construction. We now demand more pages because we expect more detail, more coordination, and more liability protection. That only happened after blueprints became the standard. Once the documents became part of the legal and contractual process, everything else followed.
  5. To say the number of sheets grew only because buildings got more complex completely ignores how the industry evolved. Complexity was a result of precision. Precision was made possible by reproducibility. And reproducibility came from blueprinting. That’s the historical sequence, whether someone likes it or not.
When I started in the mid-60s blue-line (diazo) was commonly used, but the architect I worked for still had the bid and contract documents blueprinted (wet process). I don't miss the ammonia smell, but I miss having blue-line for check sets. Black-line (xerographic) prints are used for everything now, and it is easier for a progress print to end up on the job site.
50 years ago a 30,000 - 40,000 square foot group of college buildings could be built with 60 sheets of drawings and a spec less than 2" thick. They were simpler plans with masonry bearing walls or rectangular structural grid. A lot of architects have gone to wilder designs since BIM became popular and advanced structural programs replaced slide rules and charts. HVAC systems and controls have become more complicated, sprinklers are required on more buildings, and fire alarm and emergency lighting requirements have become more stringent. Recent buildings of that size have 200 or more sheets of drawings and a 2000+ page, 2 volume project manual.
At one time bid drawings would just call for something like a 12" 5-piece cornice, and the Architect would do a supplementary full-size detail during construction.
A lot of the fat in the specs is because lawyers have become more involved in Part 1 of the spec sections and every product seems to have a couple dozen standards it needs to comply with. MasterSpec is another cause of spec bloat. It is very verbose, and the way it is written expands something that can be written if a 2 or 3 line paragraph into a dozen or more lines of single sentence subparagraphs.
  2. . . .
Calm down, Mate. My comments were not in response to your opening post. Yikes posted a link to a video. I commented that the video contained a lot of misinformation. I was asked for specifics. I provided specifics. As a licensed architect for over 50 years with 35+ years of direct experience producing construction documents, I have a pretty good idea when someone is spouting nonsense about architecture and construction documents.
I stand by my evaluation of the video to which Yikes posted a link. It is full of misinformation. If you want to watch it, do so for entertainment rather than for education.
There were similarities on post #1 and the video on several points:
3:30 Architect's shift in responsibility from artist to coordinator
5:13 Daniel Burnham changing the only copy of existing plans
5:46 Different subcontractors and trades relying on the same set of plans, rather than coordinating in the field to realize the artistic vision.
6:19 the Empire State Building example
9:03 Sears kit homes representing democratization that blueprinting brought to the design and construction profession.
Stewart Hicks went beyond post #1 and made a big leap from correlation to causation in saying that the shift from field coordination to relying on reproducible plans was the cause of standardization - -as if it were the only thing. That ignores a lot of other developments in fabrication of facade elements and building parts, the concepts in modern architecture about the "machine for living", post WW1 and WW2 impacts on building production, etc.
But it would also be a mistake to entirely dismiss the impact of drawing reproduction and the shift away from field coordination by the contractor to expecting the architect to work it all out. My grandfather was an regionally well-known architect, practicing in the 1920s when there was still an expectation that the field trades would apply their expertise and craftsmanship, even thought copying systems had been introduced by that time. He designed many mansions in our area, often with just a few sheets of plans, on buildings that had ornate ironwork, complicated masonry spiral stairs, etc. Many of the craftsmen were European immigrants who brought old-world knowledge with them.
My mother as a little girl remembers going on a jobsite visit with him and hearing him tell a finish carpenter to tear out and rebuild the stairs because "you know that's not what I expected from you"; the craftsman agreed even though the actual stair drawing my grandpa provided was very conceptual.
Fast-forward through WW2, his role becomes less of an artisan and more of a project manager / office manager as the firm grows to meet the demands of the war department, and later the postwar suburban boom. A lot of shopping center work was cookie-cutter, and there were efficiencies to be had, as the contractors increasingly expected to compete solely on low bid. The concept of "design intent" had to work its way through legal precedents. The book "A Contractor's Guide to Change Orders" was being incubated to show how the old assumptions could be exploited.
Meanwhile, my grandpa was off the boards until retirement in the early 1960s, when he designed a house for my aunt. He had a rude awakening when he found that contractors no longer had any expectation of coordinating in-field for themselves. If it wasn't already fully and completely illustrated on the plans, or rigidly defined in the specs, it was "f- you, architect".
Oh, you had to go there. :eek:
The author of that book, Andrew M. Civitello, Jr., is the son of one of two brothers who ran one of the worst general contracting companies I've ever had the misfortune to deal with. He wrote that book to proselytize his family's method of operation, which basically translated to "lie, cheat, steal, and when cornered lie some more." On one project at the far end of the state from their offices and warehouse, they needed a couple of bolts of a particular size. They submitted a change order request for the cost of a full box of the bolts (even though they only needed a couple), PLUS the cost of a truck and driver for an entire day to make a round trip from the warehouse to the site and back.
I haven't read the second edition of the book (didn't know there was a second edition until five minutes ago) but in the first edition he advocated finding all discrepancies within the bidding documents, and then NOT asking for clarification during bidding but waiting until the contract was signed, then immediately (and aggressively) pursuing change orders for "changed scope." It was that book that lead to architects including in the instructions to bidders that bidders must disclose any inconsistencies they found in the bidding documents immediately. Not 100% effective, but it alleviated many of the more egregious attempts to gaslight the bidding process.
If you note, he has a web site through which he sells the second edition. He lists himself as a construction manager. That's because the general contracting company that his father and uncle ran went bankrupt not long after the first edition of that book came out. So, like so many failed general contractors who couldn't hack it as general contractors, he re-branded himself as a construction manager.
