Why wouldn't the right one be right if it is listed?
The one on the right is compliant. That’s a sealing ring.
The one one the left is a violation of 110.3(B). Meyers hubs are only listed for use with RMC and IMC.
What do I win?
Well then, you I can trust.....but hold on.....Jeff called it a flat washer and you knew it was a sealing ring that doesn't look like a sealing ring....that's insider information.That ring came from my shop when Jeff was working with us.
I can assure you it’s a listed sealing ring with rubber on both sides.
Just a different manufacturer than the one in your pic.
Well alrighty then, it's game on Jeff
That is a possibility. It makes better sense than a lock ring and a gasket. Is this yellow gasket meant to fit inside the KO hole and the metal is meant to bite in and act as a lock ring? When I first saw it I thought that it will not repel water. I could see a gap between the minute bit of rubber that I could see and the can so I assumed that it was no good. If I was wrong, I'm happy to give them a call and take back the correction. I'll just tell them that you started it.Isn't this what was used in your photo?
That is incorrect. I'll look for another picture.Besides Ice, it appears as though those penetrations were below the level of live parts anyway so no sealing needed.
