Are windows allowed in the exterior wall of an interior exit stairway? Stairway walls are rated 2 hours. The window would be located in a stair wall that is set back 23' from the front property line, so wondering if the window is allowed and if set back this far from the property line, if it could also be non-fire-rated? Location is Washington DC, code is IBC 2012. If the window is required to be fire-rated, what is the fire rating requirement and what is the maximum size the window can be? If you can direct me to specific sections of the code that would be great. Thanks.
