Windows next to Firewalls 706.5
ppanzarella
Tampa
Per 706.5 it seems the only way to terminate the firewall at the exterior wall and have windows within 4' of the firewall is to sprinkler the building that will have the window within 4'. I am working on non-sprinklered townhomes and they are designed to have the openings within 4'. I think the only way to avoid 3/4 hr opening protection is to sprinkler the building. Is that correct?
I think I have gotten ahead of myself because i am used to working on the commercial code. This project is under the Florida residential code which doesn't require sprinklers and doesn't refer to section 706 for firewall construction. Per R302.2.1 the residential code only says the fire wall needs to extend from the foundation to the roof and the full length of the building but nothing else
The term fire wall doesn’t even exist in the residential code. The code calls for a fire-resistance-rated exterior wall on each townhouse. There’s an exception to allow a common 2-hour wall, which might be a good idea.
I was going to ask why you were asking about the IBC when townhouses are typically regulated under the IRC.
