Forum Coordinator
Whenever you have a violation that is covered by more than one code section, do you write up both (or more) or just one?
Same here.I don't provide section numbers when I write corrections so my answer is probably no.
It depends. If the only fix will fix both violations, then no. If there is a possibility that the other violation will remain. then yes I would.
