XFMR ground ring to service GE system
480v XFMR 169kva for a 3000A service.
RDP specifies that the pad mounted transformers ground ring is to be connected to the service main. It will already be connected through the neutral. XFMR is 40' away outside.
What is your opinion on this?
jar546 said:
480v XFMR 169kva for a 3000A service.RDP specifies that the pad mounted transformers ground ring is to be connected to the service main. It will already be connected through the neutral. XFMR is 40' away outside.
Recommend a new RDP
