YMCA buildout
BSSTG
Gold Member
Seadrift, Tx.
Greetings,
34,000 sq ft buildout plans in. Occ load and fixture count ok except. 1 area/room designated for child watch. Occ load listed for this room at 29. They have 1 restroom for this room for kiddos. Should they have 2 restrooms for kiddos since the occ load of the child watch room exceeds 15? Overall fixture count for the building is good otherwise.
I say yes, but am hitting a really strong headwind here.
BSSTG
Total fixture count for the building is typically all that matters, we don't get to say where they are located...(with certain exceptions of course)
Is the room marked men or women?
403.2 Separate facilities.
Where plumbing fixtures are required, separate facilities shall be provided for each sex.
What are the ages? We had a pre-k child daycare where they did not want the restrooms separated or doors on the stalls for the children. An adult was required and needed to assist the child. It guaranteed no adult was behind a closed door and alone with a child.
Check with how they will be running the program and the ages.
steveray said:
Is the room marked men or women?403.2 Separate facilities.
You, Sir, are a bigot.
Agender (non-gender): “not identifying with any gender, the feeling of having no gender.” (HTWG) “a term used to describe a person without gender. This person can be any physical sex, but their body does not necessarily correspond with their lack of gender identity” [*]
Androgyne: “1. A person whose biological sex is not readily apparent. 2. A person who is intermediate between the two traditional genders. 3. A person who rejects gender roles entirely.” (HTWG)
Bigender: “To identify as both genders and/or to have a tendency to move between masculine and feminine gender-typed behavior depending on context, expressing a distinctly male persona and a distinctly female persona, two separate genders in one body.” (HTWG)
(Nonbinary) Butch: “Holding a nonbinary gender identity and a butch gender expression, or claiming Butch as an identity outside of the gender binary” [*]
Crossdresser: “A person who, regardless of motivation, wears clothes, makeup, etc. that are considered by the culture to be appropriate for another gender but no one’s own (preferred term to “transvestite”). This gender non-conforming behavior should not be conflated with queer sexualities. Many cross-dressers are heterosexual and conduct their cross-dressing on a part-time basis. Cross-dressing might also be termed gender non-conforming behavior.” (HTWG)
Demienby: “A term indicating that the person’s gender is partially or only slightly nonbinary.” [*]
Demigirl: “Can be used to describe either someone assigned female at birth who feels but the barest association with that identification, though not a significant enough dissociation to create real physical discomfort or dysphoria, or someone assigned male at birth who is transfeminine but not wholly binary-identified, so that they feel more strongly associated with “female” than “male,” socially or physically, but not strongly enough to justify an absolute self-identification as “woman.” [*]
Demiguy: “Can be used to describe either someone assigned male at birth who feels but the barest association with that identification or as someone assigned female at birth who is transmasculine but not wholly binary-identified, so that they feel a vague association with social or physical “masculinity” but not one strong enough to justify an absolute self-identification as a “man.” [*]
Enby: Derived from abbreviation NB for non-binary. Enbyfriend can be used as a neutral romantic or sexual partner term. [*][*]
Epicene: “The term epicene literally means “common to both sexes.” It sometimes refers to individuals who have characteristics of both genders or someone who cannot be classified as one sex or the other. Most often, it refers to effeminate males.” [*]
(Nonbinary) Femme: “Holding a nonbinary gender identity and a femme gender expression, or claiming Femme as an identity outside of the gender binary.” [*]
Gender fluid: “Referring to a gender identity that changes with time and/or situation as opposed to a fix sex-role or gender queer expression” [10]
Genderflux: Similar to gender fluid, but involving a shift in “intensity”. [*][*]
Gender****: “The idea of playing with gender cues to purposely confuse, mix, or combine a culture’s standard or stereotypical gender expressions.” (HTWG)
Girlfag: “A woman who is very attracted to gay/bi men. She may (or may not) also feel she is (fully or partly) a “gay man in a woman’s body”. Girlfags may identify primarily as bi or straight or lesbian, and are often attracted to more types of people than just gay/bi men.” [11]
Guydyke: “A man who is very attracted to lesbian/bi women. He may (or may not) also feel he is (fully or partly) a “lesbian in a man’s body”. Guydykes may identify primarily as bi or straight or gay, and are often attracted to more types of people than just lesbian/bi women.” [11]
Intergender: “A person whose gender identity is between genders or a combination of genders.” (HTWG)
Neutrois: “An identity used by individuals who feel they fall outside the gender binary. Many feel Neutrois is a gender, like a third gender while others feel agendered.” [12]
Pangender: “A person whose gender identity is comprised of many gender expressions.” (HTWG)
Pomosexual: “the queer erotic reality beyond the boundaries of gender, separatism, and essentialist notions of sexual orientation”. Generally used conceptually rather than a stand-alone identity term. See also PoMoSexuals: Challenging Assumptions About Gender and Sexuality (1997).
Third Gender: Term often used in anthropological studies to set apart identities other than man or woman that appear across different cultures. Can have colonial connotations, use with caution. See also Gilbert H. Herdt’s Third Sex, Third Gender: Beyond Sexual Dimorphism in Culture and History (1996) and Serena Nanda’s Gender Diversity: Crosscultural Variations (2000).
Trigender: “People who feel they are neither male nor female, but not androgynous either and construct their own gender.” (HTWG) Trigender may also be used to refer to one who moves between three genders, as bigender is used to refer to those who move between two genders.
Transmasculine: “A term used to describe those were were assigned female at birth who feel wholly dissociated from female gender identification, and are, if not wholly male-identified, are at a place much closer to that end of the binary spectrum, either through a preference towards behavioral or physical “masculinity,” or through being in a state similar to that of a demiguy, where they may feel “weakly male,” but not very attached to the idea of being a “man.” [*]
Transfeminine: “A term used to describe those who were assigned the male gender at birth, but who feel wholly dissociated from male gender identification, and who, if not wholly female-identified, are at a place much closer to that end of the binary spectrum, either through a preference towards behavioral or physical “femininity,” or through being in a state similar to that of a demigirl, where they may feel “weakly female,” but not very attached to the idea of being a “woman.” [*]
Brent.:-D
