jetlag1946
In the past plumbers always set the tub and connected it before the rough plumbing inspection . Now I am total confused on that . The inspector wants to do the rough plumbing inspection before he okays for insulation to be installed . When he inspects the insulation he does not want the tub/shower in place because he wants to be sure the wall behind the combo is insulated and also has an air blocker on the wall behind the combo . How can he inspect the insulation with the air block over it ? Does he consider the rough in plumbing complete with the pipes caped and not connected to the tub ? Someone please explain the procedure to me. I am getting ready for a rough inspection . As you know the tub must be set before the dry wall is done .
