Mr. Inspector
A little change of subject. But I have some problems on pools and would like how other inspectors think about it. We use the 2009 IRC and I don't know if newer codes fixed these things.
1. Someone is building a deck next to a aboveground pool. No connection to the house. Would you make them have a light for the stairway as required by IRC R311.7.8?
Or since this is not a means of egress from a dwelling the stairway does not need to comply with code at all? The removable stairway or ladder for aboveground pools never meet the stairway requirements. Would you let them use the removable stairway/ladder to get on this deck?
2. Does the door alarm for a house sliding patio door for a pool area go on the glass door or screen door or both?
3. If a large operable window with a low windowsill with or without a screen that opens to a pool area need to be kept somehow from a child to go through it?
4. IRC AG 105.2 requires the top of the pool barrier to be at least 48' above grade. I always took this as meaning a walking surface rather than grade especially for a deck that connects a house to a pool. But the this section also requires less than a 2" space between grade and the bottom of the barrier. I could understand it the barrier was on the ground but is this still needed if the barrier is on a deck or a paved surface?
