Michael.L
I'll admit: it took me a few days of pondering to finally understand why extra clear floor space was needed for doors with both a closer and a latch, but not for a door with either a closer or a latch. Additionally, I couldn't imagine a scenario where a single-occupancy restroom would have a door without some way of securing it for privacy.
Then it dawned on me that a "latch" must be defined as a spring-loaded device that the user must perform an action upon in order to release the door (turn a lever, press a paddle, etc) and that the user must continue to hold that "latch" in the released position (against the pressure of the latch's spring mechanism) while the door is then being pushed or pulled open against the force of the closer. In other words, the user must perform two separate but simultaneous actions: (1) hold open the latch against spring pressure; and (2) push or pull open the door against the pressure of the closer.
Remove the closer, and the user can release the latch and then freely swing the door open.
Remove the latch, and the user can simply push through the door (or pull it open).
Add both a closer and a latch and it becomes very challenging for a disabled person to perform both actions at the same time. Hence the need for additional maneuvering space.
Am I understanding this correctly so far?
So that leads me to four questions:
1. If a door has a closer and a deadbolt for privacy (with no spring-loaded "latch" that automatically secures the door when the door closes), does that negate the requirement for additional clear floor space?
2. Is it permitted to have a door to a single-occupancy restroom with only a deadbolt, but no latch?
3. If the previous two questions are true, is this widely known and accepted by inspectors?
4. Is there any ADA code reference that specifically backs this up?
Just to be clear, my definition of a deadbolt would be a manually-activated device that has an operating lever on the inside and a keyed cylinder on the outside. The deadbolt requires a user to perform an action on the inside lever to lock or unlock the door; the bolt remains in whichever position is selected by the user. For a single-occupancy restroom, the deadbolt would have an indicator that shows that the restroom is "Occupied" when the deadbolt is locked, and "Vacant" when the deadbolt is unlocked.2. Is it permitted to have a door to a single-occupancy restroom with only a deadbolt, but no latch?
