Never saw a pool so close to a house. Would you make them bond the rain gutter and window frame to the pool bonding system now or only when the pool or rain gutter or window is new?
Do you require the other appliances to be elevated as well (I see gas piping so I assume gas dryer). We have had to differing opinions about that.
Second unit?
Not sure as I didn't get that close. Of course the rules have been watered down to accommodate converted garages so if it is a second unit a permit will fix that.Second unit?
2013? codesSome jurisdictions accept a document in lieu of inspecting smoke and CO alarms. And by the way, they are not detectors.....don't say smoke detector or Co detector. A detector isn't going to wake you up. Well anyway, I have seen a few of the documents stapled to a job card like I will inspect whatever and not need to go inside. I have said no because I detected dishonesty and found no alarms. I just wanted to use the word detected in a sentence. I would never accept a document. I've even see them with a Notary seal. It's only been a handful of times and each time there was no detectors....or alarms either.
Today was a good example of the level of competence found in the solar industry. The guy handed me this with all the confidence in the world that I would just move on.
Even with the CA ADU Guidelines, there is still setback requirements, not met. Lateral, Stair construction, stairs in "fire in rated areas", fire rating of construction and openings, zoning. some requirements are not exempt.Not sure as I didn't get that close. Of course the rules have been watered down to accommodate converted garages so if it is a second unit a permit will fix that.
All that and you haven't been inside. If the sheet metal roof is any indication, there's bound to be issues.Even with the CA ADU Guidelines, there is still setback requirements, not met. Lateral, Stair construction, stairs in "fire in rated areas", fire rating of construction and openings, zoning. some requirements are not exempt.
