Mr. Inspector
Usually I let them have a space less than 4" between the guard top rail and a wall.
Nowhere does section 1013 says the top of the guard is to be continuous except at stairways or anything like that. So I go by the following:
1013.3 Required guards shall not have openings which allow passage of a sphere 4" in diameter from the walking surface to the required guard height.
But at this S building the top of the rail stops 5.5" from the wall with a vertical support which leaves an 5.5" opening. The exceptions for group S buildings let's you have a 21" opening in the barrier. The top rail is part of the barrier. Does this mean they can have a gap of 21" between the guard top rail and the wall?
