Not sure I understand the derating. The 60 & 75 issue I know.
Well let me give it a shot.  There are two reasons to derate the ampacity of a conductor.  One is ambient temperature and the other is the proximity to other current carrying conductors.  If the temperature exceeds 104° or there are more than three current carrying conductors in a raceway, the ampacity drops.
Start with table 310.15(B)(16).  Find the wire type and gauge to determine the allowed ampacity.  It can be 60°,75°, 90° depending on the insulation type.  For example THWN is found in the 75° column while THWN-2 is found in the 90° column.
Next is the temperature.  Table 310.15(B)(2)(b) gives the percentage of the ampacity that is permitted at a given temperature.  For example, at 125° a wire found in the 90° column of table 310.15(B)(16) is allowed 84% of the ampacity that table 310.15(B)(16) identified.
Here is an example:  12 awg THHN wire is in an attic with an ambient temperature of 113°.  Using the tables: 30 amps x .95 = 28.5 amps.
There is another consideration for raceways and cables exposed to sunlight on a roof.  Table 310.15(B)(3)(c) provides a temperature adder  depending on the height above the roof.
Moving on we come to the issue of more than three current carrying conductors in a raceway.  That takes you to table 310.15(B)(3)(a).  Wires in proximity to expanding and collapsing magnetic fields have a current generated within them.  That current is small and worthless but it will generate unwanted heat.  So as a result, if there are more than three the is a percentage of the ampacity given in table 310.15(B)(16) that is allowed based on the number of conductors.
Here is an example: There are 18 THHN #12 awg wires in a conduit.  Table 310.15(B)(3)(a) allows 50% of the ampacity given at table 310.15(B)(16)  30 amp x .5 = 15 amp.
Note that neutral conductors that carry the unbalanced current of multiwire circuits are not counted as a current carrying conductor.
Jeff's example didn't specify a wire type so I'll use the most common 12 awg which is THWN-2.  That wire is found in the 90° column and has an ampacity of 30 amps.  The raceway is 8" above the roof and table 310.15(B)(3)(c) requires the addition of 30° in temperature to the ambient 91° in the example.  At 121° the value found in table 310.15(B)(2)(b) is 85% .  30 amp x .85 = 25.5 amp.
Writing this down made it seem like a lot of information but the reality is that it is easy peasy.
