Wire in Conduit on a Roof
Riddle me this:
You have 3 WR GFCI duplex receptacles on a single 20A circuit that serves mechanical equipment on a roof.
The conduit is on stands approximately 8" above the roofline. The area has a design temp of 91F as verified by the 2% ASHRAE design temp for June-July & August.
What size wire would be code compliant for this installation based on NEC 310.15(B)(3)(c)? No other factors such as conduit fill is applicable for this. Enjoy!
And the answer is:
No one on this forum does commercial electrical inspections.
HOWEVER, this can easily be found on the flat part of a residential SFR with a flat roof so maybe this oughta be looked at.
I'll take a stab at it (I just needed a weekend day when I had a little free time)
3 receptacles = 3 x 180 / 120 = 4.5A
91 + 60 = 151 deg. ambient
Try #12 - for 75 deg. ambient conductors ampacity = 25 x 0.38 = 9.5A
#12 is adequate.
It would be prudent to use 90 deg. conductors to allow for additional future loads.
Odds are great that a 90° wire has been used. 90° #12 is rated at 30 amp. 8" above a roof in a conduit has a temperature adder of 30° which results in 121°. The multiplier for 90° wire at 121° is .89. 30 x .89 = 26.7 amps
We have a different take on the temperatures to use. Conduit exposed to direct sunlight has been determined to be 113°. That results in 143° with a conduit 8" above a roof and the multiplier is .71. 30 x .71 = 21.3 amps
Are the connections on the receptacles rated for 90 degree wire?
Not that I am aware of.
The ampacity is limited to the 60° and 75° columns.....but if the wire is 90° then you can derate from there.
Not sure I understand the derating. The 60 & 75 issue I know.
Well let me give it a shot. There are two reasons to derate the ampacity of a conductor. One is ambient temperature and the other is the proximity to other current carrying conductors. If the temperature exceeds 104° or there are more than three current carrying conductors in a raceway, the ampacity drops.
Start with table 310.15(B)(16). Find the wire type and gauge to determine the allowed ampacity. It can be 60°,75°, 90° depending on the insulation type. For example THWN is found in the 75° column while THWN-2 is found in the 90° column.
Next is the temperature. Table 310.15(B)(2)(b) gives the percentage of the ampacity that is permitted at a given temperature. For example, at 125° a wire found in the 90° column of table 310.15(B)(16) is allowed 84% of the ampacity that table 310.15(B)(16) identified.
Here is an example: 12 awg THHN wire is in an attic with an ambient temperature of 113°. Using the tables: 30 amps x .95 = 28.5 amps.
There is another consideration for raceways and cables exposed to sunlight on a roof. Table 310.15(B)(3)(c) provides a temperature adder depending on the height above the roof.
Moving on we come to the issue of more than three current carrying conductors in a raceway. That takes you to table 310.15(B)(3)(a). Wires in proximity to expanding and collapsing magnetic fields have a current generated within them. That current is small and worthless but it will generate unwanted heat. So as a result, if there are more than three the is a percentage of the ampacity given in table 310.15(B)(16) that is allowed based on the number of conductors.
Here is an example: There are 18 THHN #12 awg wires in a conduit. Table 310.15(B)(3)(a) allows 50% of the ampacity given at table 310.15(B)(16) 30 amp x .5 = 15 amp.
Note that neutral conductors that carry the unbalanced current of multiwire circuits are not counted as a current carrying conductor.
Jeff's example didn't specify a wire type so I'll use the most common 12 awg which is THWN-2. That wire is found in the 90° column and has an ampacity of 30 amps. The raceway is 8" above the roof and table 310.15(B)(3)(c) requires the addition of 30° in temperature to the ambient 91° in the example. At 121° the value found in table 310.15(B)(2)(b) is 85% . 30 amp x .85 = 25.5 amp.
Writing this down made it seem like a lot of information but the reality is that it is easy peasy.
ICE: I understand your breakdown. I guess the term derate has me not fully understanding. I get all the other factors you explained and the examples. May be a senior moment! LOL! My first thought was the photo looks like Florida!? The 91 degree temp for an average day ok, but on a roof it is much hotter. I may be just over thinking the OP.
I did it for a few inspectors that I work with. This is the topic of an upcoming training class. Seems odd that they can stretch this into two hours. I will print this and hand it to electricians that get the correction to derate. So often they have never been given that correction and they assume it to be a conduit fill correction. So when I do a follow-up inspection they went from a 1" EMT to 1.25" EMT. Now I have a fight on my hands because they didn't understand.
Recently I spent ten minutes in conversation trying to educate a contractor. He couldn't get past the conduit not being too full. He was loud, argumentative and interrupted me constantly. After a while he shrugged and said, "Can I use the 90° column". That's when I knew that he knew but kept resisting in a hope that I would give up or perhaps not know the code as well as I let on. I was done with him.
This will help some but most of them don't have a code book so not much helps them.....well unless I do the math and give them all of the options......I don't like doing that because when that turns out wrong they claim that they did exactly what I told them to do......or they find out that #10 wire would have worked but they installed another raceway instead. It's just not my job man.
We ask to see a contractors license before we issue a permit......we should ask to see their code book too. No code book = no permit. Come back when you are making a genuine effort to be an electrician.
Spot on. This should apply to "builders" as well.
Well in PA you can get the license on line with a Visa card. ICE I totally understand your second or last statement. I agree they could have used a 10 wire given all the correction factors. Looking back over this the term derate I just never use or heard of.
