Many cities around Texas have local plumbing codes that build off larger codes, including the Uniform Plumbing Code, a policy developed by International Association of Plumbing and Mechanical Officials, and the International Plumbing Code, developed by International Code Council. Without the state code, regulation will probably go back to the cities and municipalities, Wakefield said.
Plumbing is not only about knowing that sh-t runs downhill.
Minimum competence levels are established by the certification agency and provided they are following a standard, like ISO 17024, litigation will be challenging.So, you want to further enrich the "suits" of the world eh? I guess there aren't many esq's in PA?
Basis of E & O claims is contract language and lack of competence. How do you prove "minimum" competence? Hire an "expert". You want a return to Hammarabbi (spelling?) ?
They are self-regulating. In order for the provincial or federal authorities to accept their private member bill to restrict their trade to only those that have certification through their organization they must demonstrate that the certification scheme functions: enough people to meet demand, both now and due to turn over; have proper controls in place for certification, investigation, discipline and stripping members of certification. Architects, engineers, interior designers, plumbers, electricians all have these schemes in my province.The "keyword" is "provided", who verifies that they do? Do you allow design/build in Canada?
After everything was complete and inspected I had to call an appliance repairman who came out and modified everything for propane.
No, when the order was placed I did request them but they came with gas orifices, when I called to complain I was told that a factory trained appliance repairman had to bleed the lines and install the propane orifices. When the inspector walked final and turned them on he got a dull red flame.You couldnt order new propane orifices yourself?
This is actually somewhat typical...manufacturers playing CYA before someone blows themselves up.No, when the order was placed I did request them but they came with gas orifices, when I called to complain I was told that a factory trained appliance repairman had to bleed the lines and install the propane orifices. When the inspector walked final and turned them on he got a dull red flame.
Because cross connecting gas lines, like oxygen/nitrogen, can kill people.So if Licensed Plumbers keep us safe then why must those same Licensed Plumbers have inspections? Shouldn’t by all accounts any of those Licensed trade professionals, plumbers, electricians, hvac, be exempt from inspections, they do test to a competent level, must have active insurance and shall maintain the mentioned and be registered with the state.
Not "all" plumbers employees are "licensed", just as most CM's lack licenses and trade experience (working under a GC's license who rarely walks their jobs)
Inspectors are often our only line of defense against them.
I'm a medical gas installer, all of our work has to be approved by a third party verifier called an ASSE 6030 Verifier, regardless of competent we are. The issue that just happened in Georgia with the Nitrogen leak is a good example of why third party certifications and inspections are a good thing.Well duhhh. Again they test at a competent level just as I have and I’m going out on a limb here based on your comment but you did as well. So have you approved that type of cross connection or did your competency test prevent that, rhetorical question!
Something recent?The issue that just happened in Georgia with the Nitrogen leak
