Jabbing anchor bolts in wet concrete is not fine and any contractor who says it is ok should have his license revoked.
While I said concrete I could just as well said grout. For this discussion there is no difference.
Am not aware of any code that has provisions for anchor bolts or anchor rods in the joints between masonry units. So why are they accepted?
All the concrete block construction that I have sees uses hollow block where the cells can be filled with grout. The bolts are then inserted in the cells before the cell is filled with grout. The picture suggests that there were hollow cell blocks on the project.
Just because it is a regional practice does not mean that it makes sense or is code compliant.
There is a phenomena know as normalization of deviance. This played a significant role with the failures of steel moment frames that we found after the Northridge earthquake. What happens is that if people accept deviations from the code too often the deviations are seen as the new normal. The process repeats itself.
I can hear a lot of screaming and shouting but I believe that a lot of there problems would be avoided if engineers were involved in the design of houses.
I also believe that each building department should have at least one registered civil engineer
I'd have to fail every job I see if that were true
where in the USA can you still do a SF for $100 sf?
I refer to civil engineers because in many parts of the country there is no structural engineer license and because in California a civil engineer can perform the engineering on any project where the local building department would have jurisdiction. The jurisdiction hiring the individual can always impose higher qualifications.
The problem is that in too many instances an inspector or building official is put in a situation where he is asked to make decisions about engineering issues when he doesn't have the education or training necessary to make those decisions. The engineer would be better qualified to make those decisions and to help train the inspectors.
The knee jerk response that there are also poor engineers is an attempt to deny that there are problems that an engineer could help address. Remember as an employee of the jurisdiction the jurisdiction is in a position to get rid of a poorly performing engineer. If the comment about cost was about the jurisdiction being unwilling to pay for a qualified engineer then I suggest you have bigger problems because that implies that they would have similar attitude towards the inspectors.
The practice of the City of LA was an illegal attempt to try to make the engineer of record responsible for the constructed work even though he has no control of the work. The building department should focus on performing their inspections and not try to shift responsibility.
