EMT to FMC
Forum Coordinator
Somewhere Too Hot & Humid
The range location was changed for this condo kitchen remodel. They used FMC to connect to the EMT for about 18”. What is wrong and why?
Back to the OP ... looks like there might be more than 360 degrees of bends in the flex.
Reactions: ICE
Does the connection need to be accessible? How is it different ... in theory ... from a joint in emt?
The issue here is that FMC is only rated at 20 A using it as an equipment grounding conductor, in this case, extending the EMT. This is a grounding issue. This is a 50 amp circuit for a plug-in range. I thought I put this in the electrical section, not sure why I’m getting drywall screw comments.
