LGreene
I was contacted about an antique barn that has been repurposed as an event space. The calculated occupant load of the barn is 140 people based on the unconcentrated assembly occupant load factor and I will verify that they have at least 2 egress doors with panic hardware.
Here's the question for you. There is a 3,000-SF deck attached to the barn, which has its own exits to grade (it's 1 story up). The local fire department is saying that the deck does not increase the allowable occupant load of the total event space, because people on the deck might enter the barn during inclement weather, thereby increasing the number of people in the barn above 140.
I have never heard of this. I would have expected the barn and the deck to have two separate occupant loads, since each has its own means of egress. I also thought that the calculated occupant load was used for determining the required amount of egress width, the number of plumbing fixtures, etc. I didn't think the purpose was to establish the maximum number of occupants that the barn could hold. And if the fire department is trying to come up with that number, why not use the concentrated use factor and then check to make sure the barn has the means to support that number of people?
Can you help educate me?
