10.10.2.1.3 The minimum rate of flow shall be not less than one of the following:
(1) Hydraulically calculated water demand flow rate of the system, including any hose requirements
(2) Flow necessary to provide a velocity of 10 ft/sec (3.1 m/sec) in accordance with Table 10.10.2.1.3
(3) Maximum flow rate available to the system under fire conditions
do you require a certain diameter flush such as full diameter flush, or one 2 1/2 inch hose, or half the diameter or etc.
when a flush is done???
or does it depend on the size of the pipe?????
