Daycare Enclosed Playground
Joe369369369
Hoboken NJ
Hi and thanks for your help and time with this.
I have an operational daycare center in NJ with an enclosed fenced in courtyard which I am trying to use as the designated "playground" for the childcare center.
I was told the area needed to have a direct path to the street in order to be useable.
However, after looking at the code its my understanding that this is only required if the path leading to the playground is a means of egress for the space. It is not, there are two other egress areas leading directly to the street. The minimum distance to one of these exits from the playground is met.
The building is fully sprinklered. and there are actually two doors in the enclosed courtyard but both lead back through the building.
Thanks for any help.
If the playground has a >50 OL then the doors need to swing into the building and there needs to be two of them, likely with panic hardware.....
WHO told you city, or another agency???
Without a floor plan, a little hard to make a call.
About how many sq ft is this area??
Thanks for your replies guys.
The state daycare licensing board said usually a direct exit from the playground to the street is required.
But wouldn't that be only if the door leading to the playground was a means of egress for the daycare center.
Here is a floorplan.
Sometimes the day care gods, play by their own rules,,,
Which may not match building code,, But you have to meet.
Seems to me a direct access to the street would be a security issue. Both kids escaping and people sneaking in.
If floorplan image has an exit door to the playground then correct the playground needs egress to public way or code compliant gathering area distanced and sized.
Would not be running the kids back into the building.
