The slab was probably sized to fit the building frame, drilling holes outside the slab will require stretching the steel.Or drill holes on the outside of the slab, set the posts and build the building.
Thank you, I will come back and update as I’m able to. I work nights and it makes handling business during the day considerably more challenging. Yes, it looks like I will require permits. I’m not necessarily worried about snow or seismic activity. We rarely get more than 2” of snow a year here. Wind is a concern as we’re part of the “Dixie Tornado Alley”. I should have been more clear. The electrical line is my 240v service coming to my house. It looks like if I had the slab repoured in front of a section of the ”current” slab I’d have 7.5ft of clearance from the service line horizontally. However, the slab would be touching the concrete footer of my stairs. I’m unsure if this would be an issue or not. I’m still waiting on the building plans so that I can contact someone with more solid information.$ ~ $ ~ $
Grape_Ape,
Welcome to the Building Codes Forum !
IMO, ...** Mark K ** has the most accurate response
[ RE: Post # 13 ]........The other responses have
merit too, but I too believe that you should be
discussing this project with an architect or engineer
who has your interests in mind and not some metal
bldg. company wanting to just sell you something.
Even if no permits are required, ...serious consideration
should be given to the requirements of the Wind,
Snow & [ possibly ] Seismic Loads for your location.
A foundation should be so designed to resist the various
loads \ forces that will be acting upon your metal bldg.
The footings are designed to resist the uplift forces of
the wind, to keep your metal bldg. from separating
from the foundation when; not IF, a strong wind event
comes thru your area........Also, there is consideration
for the Snow & Seismic forces for your location.......All
of these should be addressed in writing by a Registered
Design Professional [ i.e. - an architect or engineer ].
You also have questions about the actual location on
your property because of electrical lines.
Because you have so many variables to your application,
no one on this Forum can provide you with all of the
correct answers that you have.
IMO, ...hire someone to serve your interests and has
first hand, on-site knowledge.........This investment will
pay for itself.
P.S. Whatever you come up with, will you please come
back on this site and let us know the outcome ? Thanks !
Hopefully that’s an option if cutting the slab and pouring footers is not. A pole type building will be more expensive but at least I have the option to add walls and things at a later date. I‘d assume it will be cheaper than redoing the slab completely however.Or drill holes on the outside of the slab, set the posts and build the building. There's no way I'd tear out the slab (or make someone tear it out as the B.O.) if a pole building is what's going over the top of it.
I’m hoping from what I understand my setbacks wont be a problem. The house is sitting almost directly in the middle of a 4 acre lot. So I’m hoping that all of the setbacks are more than cleared.You also need to check with your county or town zoning. Most jurisdictions have minimum setback requirements (distance from property lines).
It might be possible to cut a couple feet off 2 sides of the slab, then pour a new slab with turned down edges on top of it, so the garage is offset a foot or 2 from the present slab location.
Reinforcement in a garage residential is mostly to minimize cracking. Fibers mixed into the concrete are another way to do this.
Okay, thank you. I will follow up with these ideas and see where I can get with it.Cut it back a foot all the way around. Pour new footing four inches higher than slab every where except where the roll up door is and put building on top of footing.
Yes will need expansion joint between slab and new footing.
Or go with the pole barn or metal building that uses columns and purlin. These will have spot footings at columns and would only need to cut where the columns are located. This still usually requires an engineer.
Yes, that is how the slab was sized.The slab was probably sized to fit the building frame, drilling holes outside the slab will require stretching the steel.
Could you give me an idea of what information you’d need? I have generic building plans they sent me but don’t want to plaster them all over the web just for any potential liability. I’d be happy to look for anything you’re wanting to see though.Footings are usually wider than the foundation wall. The required width depends on the load from the walls (or columns) and the bearing capacity of the soil.
Do you have a link to the garage website?
Does the building vendor have recommendations and connection details for the foundation?
Are you in a high wind area?
Thank you.Concrete floor 6 inches above adjacent grade. Slope 6 inches down from there, within the adjacent 10 feet. Code sections attached.
What I posted is all that the building plans offer.I see no mention as to Foundation requirements?
This is all I have for spacing on the posts. Doing some research from another manufacturer and they say the end posts are typically spaced 4-5 feet apart depending on wind certification and snow load.The anchorage drawing you posted makes it look the exterior wall is a bearing wall with studs. If so, you can use these tables.
A lot of metal buildings have columns & frames 10 feet or more apart. That creates a concentrated load which requires larger footings under the columns, which will probably require engineering.
Grape_Ape,
Thanks for the updates !..........On the documents
that you submitted, I did not see information on how
the roofing system will be attached........Since you
are in the Dixie Tornado Alley, I think that these
details would critical, or did I miss the details ?
IMO, the company that you have a deposit with is
just trying to sell you their product without any
real concern as to how you will anchor it to a
foundation.
Q1): Are the bldg. plans that you have, stamped &
signed by a registered structural engineer ?
Q2): Has the metal bldg. company provided you
any guidance for a foundation for their product, or
even mentioned that you should be talking with a
Because you are located in a known "high wind
area", ...you already know that tornados can
easily exceed the "designed wind loads".
Q3): Have you given consideration to the "probable"
higher wind loads on this bldg. ?
Id bet $100 to a dime that their stamp has a disclaimer, that it only applies to the building and not yo the foundation. And there is probably a note that says all local codes must be followed.A1): Yes, the plans I’ve been referencing and sharing are stamped by a PE and approved up and down the east coast. From New York and Massachusetts all the way to Georgia and South Carolina.
Why would home insurance not insure a DIY install that has permits and passed inspection? That’s what I’m working on right now. The building itself will be installed by installers.Have you checked with your insurance company yet as to whether they will insure a DIY install?
