John shane
Hi Everyone,
So we are redesigning an existing residential apt and we are providing a heat pump water heater because the house doesn't have gas and more so we can't pass t24 with an electric water heater.
We all know that environmental air exhausts termination need to be 3ft away from openings into the building. Now, is a heat pump's discharge air considered as an environmental exhaust and would need to follow that termination clearance too? As far as I know some installations even install discharge of a heat pump with 2 way ducts so that in summer you can use a damper and direct the cold air for additional cooling to the house.
The only place that we could duct it is to a wall is in between 2 windows, the wall length is just 3 feet so we won't be able to comply with the requirement.
Honestly I just think that I can do it as it is clean air that is being discharged to the environment. Wdy guys think
