I am buying a new house in Florida. The house is being built by a major builder in the area. They don't promise much to me, other than that the house will meet code. To my unprofessional view, their construction method doesn't meet code. Details follow:
They are building a shower with steel studs, conventional paper gypsum board, and thinset tile. They are not using a tile backer and not using a waterproofing system on the gypsum board. They are simply using Gold Bond High Strength Lite 1/2" drywall for the walls. At this time, their tile work is done and the construction details are hidden.
"R702.4.2 Fiber-Cement, Fiber-Mat Reinforced Cementitious Backer Units, Glass Mat Gypsum Backers and Fiber-Reinforced Gypsum Backers
Fiber-cement, fiber-mat reinforced cementitious backer units, glass mat gypsum backers or fiber-reinforced gypsum backers in compliance with ASTM C 1288, C 1325, C 1178 or C 1278, respectively, and installed in accordance with manufacturers' recommendations shall be used as backers for wall tile in tub and shower areas and wall panels in shower areas."
I found the manufacturer's spec for "High Strength Lite" and it doesn't include any of those standards. So if I read this correctly, they are violating building code. But the county inspector approved. I have in-progress photos showing conventional drywall on the shower wall. But someone could argue that they photos don't prove that the drywall is conventional. Seems that the only way to prove this is to rip it apart, and that's not going to happen easily.
So what do I do?
Do I argue that their work doesn't meet code and tell them to fix it?
They will certainly state that they got a certificate of occupancy, so I must buy. They will also argue that's how they build all of their homes. They might also say that tile and drywall are done by licensed subcons, so they've met their obligation.
What's a buyer to do in this situation?
Thank you for your advice.
So what do I do?
