How long does it stay active?
Thursday was active, Wednesday was notHow long does it stay active?
I'm definitely not seen one anytime! Guess I need some help.
The Fire Department has set criteria that everybody has to abide by. It is generally not difficult to arrive at a conclusion regarding sprinkler requirements. The decision in this case is clearly the purview of the Fire Department.Plenty of BLAME to go around BUT At the end of the day, DOES THIS ADDITION REALLY MAKE THIS HOME UNSAFE?
Most likely the original Structure was Sawn Lumber and not I Joist with a 3/8 OSB Web
Was the Addition Sawn Lumber? Personally, I feel the "NEW" Lumber options and how quickly the structure could be compromised is the main reason for the sprinklers
I understand where recent thinking is that anything that gives the occupants more time to Get Out is a Good Thing
But perhaps some extra smoke alarms would be just as effective as an Early Warning Method
I believe that Fire Alarms SAVE LIVES and Sprinklers Save Property
The idea of creating a financial Hardship for this oversight seems unreasonable IMHO
Ice, Point Taken! The Legality of the situation and the RIGHT of the AHJ to Insist that they can ignore their part in this situation is clear.The Fire Department has set criteria that everybody has to abide by. It is generally not difficult to arrive at a conclusion regarding sprinkler requirements. The decision in this case is clearly the purview of the Fire Department.
As to creating a hardship….an architect designed it, a contractor built it, an owner sat on it….so who created what?
These are separate permit types. Sprinklers are never a part of the building permit. So that sure is helpful.Was there a rough-in inspection approved? at what point does the sprinkler system get inspected? Are water connections to a sprinkler system done by a plumber or the sprinkler installer? Where's the GC on this project?
Sawhorse member shoud have the edit button, shows up after you post the in the lower left next to Report
Me & Msradell are in the say boat. I remember the edit but do not see it. I renew in Oct. I'll see if it returns. Sorry for hi-jacking the thread.I'm definitely not seen one anytime! Guess I need some help.
Scenario: Sprinks are required. This forum has documented in writing you know this. You "pass it and move on". An unfortunate fire occurs and people are seriously injured or die. Everyone is sued. The judge asks you if you passed something you knew was a code violation. You say yes but "it was caused by the failures of a previous administration".I was being facetious - however my guess is that someone the OP has spoken to in the city thinks that is a legitimate option...
Now, for a helpful answer - pass it and move on. You are a new B.O., and you cannot be held responsible for the work of your predecessors. Save your willingness to stand firm for a situation that happened during your employment. The homeowner did not know anything about that requirement, and it wasn't called out by anybody ahead of time.
The time to act was before, now is too late. Clearly document who dropped the ball, clearly inform everyone involved that a violation exists and that you will not pursue it from an enforcement standpoint because it was caused by the failures of a previous administration, and call it a day.
Edit: I re-read the OP, and if the architect was notified in writing, I think you should stand strong. Please disregard the previous answer, I had assumed no one had been informed at all.
ICE, Point Taken, there was a Mistake, Like someone once pointed out to me:The Fire Department has set criteria that everybody has to abide by. It is generally not difficult to arrive at a conclusion regarding sprinkler requirements. The decision in this case is clearly the purview of the Fire Department.
And he needs something to do.@ ~ @ ~ @He is always willing to help !
It is not a matter of "would have triggered"....it was triggered at inception. The current situation has not changed that. The responsibility rests with the owner. What the owner does about it is not the problem of the building department. The building department can't cause the owner to install a sprinkler system and the owner can't cause the building department to issue a C/O.So 2.5 years later, due to covid, the owner calls for final inspections and my inspector realizes that this home would have triggered the fire sprinkler requirement.
