Intermediate turnaround direction?
Yikes
Southern California
In the image below, "Figure "B", it doesn't say which direction the fire trucks are coming from.
I would like to use this figure "B" as a dead-end turnaround at the end of a site that is 500' long and only 100' wide (too narrow for T-turnaround Figure "A").
the red bar marks the end of the site.
I'm hoping that the trucks can approach from the direction marked "1". Does that work?
I would say yes. Take a look at Appendix D in the IFC. What you are describing is used as an alternative to the hammerhead. However, the version in Appendix D does not give a minimum dimension on the terminated end (where you have shown a red line). Using the hammerhead as a guide, the terminated end should be at least 60 feet from the centerline of the intersection.
RGLA, in the drawing above ( from LA County Fire Code), the distance from the dead end to the centerline is 27’ + 10’ + (1/2 of 28’) = 51’.
What I can’t figure out in the sketch is why one leg is 27’ and the other is 35’.
I cannot say, either. I guess the LACFD is unbalanced. :p
It may be a good idea to have your civil (or someone with a swept path simulation software, like AutoTURN) model LA County's fire apparatus. We had a multi-family project on a tough site that I had to model a tractor-drawn aerial truck ("hook-and-ladder") to determine what we needed for a dead-end hammerhead.
Would they allow bat-wings in the Right-of-Way above the top of the curb? Forms a cal-de-sac like figure-C
Not much different from the State Fire Code, 2019 California Fire Code, Title 24, Part 9​
