All garbage is being torn out. Fresh start on electrical.I think someone should repair the electrical conduit.
Yes, correct.SDR....they are gasketed....only allowed outside...
I didn't say it was required...I said that it "should be."Only applicable if it is a vent:
905.3 Vent Connection to Drainage System
Every dry vent connecting to a horizontal drain shall connect above the centerline of the horizontal drain pipe.
Noting again, not a code requirement - more a best practice.How would you recommend \ suggest to someone installing the
connecting fitting to have it above the center line, ...especially if the
6" drain line is already in-place & sloped ?........Just sayin'...![]()
The next time I write a plumbing correction, that word will be there .... and I don't care what the correction is about .... it could take a paragraph or two but I'll get it in there. I might get sent to equity training ... again.accretion
And 3" of lost elevation on a 6" line pitched at the minimum 1/8" would affect 24' of pipe before it.....What is worse, a flatter pipe run or that connection?Noting again, not a code requirement - more a best practice.
I will say that to roll the pipe above mid-line would only be about 3" of lost fall.
Flatter pipe likely.And 3" of lost elevation on a 6" line pitched at the minimum 1/8" would affect 24' of pipe before it.....What is worse, a flatter pipe run or that connection?
What's the problem? Looks to comply with IPC 705.10.1. Fernco 1056 series is for connecting " CI, PL, Copper, ST or Lead to CI, PL, Copper, ST or Lead".I would call out for the fernco’s, use gasketed slip couplings that are designed for this pipe.
24"? I thought we were talking 6&12"?.....If it is in the ROW and under the control of the utility, then it is whatever they want....The 24" pipe is the public sewer. The connection is in the ROW and off the private property. Does this change anyone's mind?
Apparently somebody called the wrong department for an inspection.Does this change anyone's mind?
