But the rating in T601 is for the structure, not the openings.....Not to say that the framing for the opening at the opening might not need to be protected, but protected as structure, not as a penetrations...I would say yes, install fire dampers and rate the wall based on Table 601.
[BG] SECONDARY MEMBERS. The following structural members shall be considered secondary members and not part of the primary structural frame:
1. Structural members not having direct connections to the columns.
2. Members of the floor construction and roof construction not having direct connections to the columns.
3. Bracing members other than those that are part of the primary structural frame.
Spray fireproofingHow do you protect the roof structure if you do not protect the opening?
You protect it in the same manner you are already protecting the rest of the structure...Spray, drywall, whatever....Protected construction protects the structure....it does not slow the spread of fire.....Think Parking garage...generally fire protected and one big opening...Over the entire primary and secondary members?
I think a rated wall with opening protection would be less expensive.
If this is in an International Wildland-Urban Interface Code area, then soffit and gable ventilation protection maybe required anyway.
Metal Gable Vents | Louvered Fire Safe Vents - Vulcan Vents
Vulcan Vents makes fire-resistant Metal Gable vents. Our Louvered stainless steel vents are installed on the exterior walls entry point of home for embers.www.vulcanvents.com
I don't like the fact that B might shoot the exhaust from the RTU into the attic, but not outright prohibited without more infoQuestion: do you see a fundamental difference in attic vent opening protection requirements in (A) vs. (B) below?
If so, what?
