socaldano
I am an engineer in another discipline from construction, and I project manage my own properties/projects.
All my properties are residential.
We work hard to make sure all my work is to code.
Most contractors in the area avoid getting permits because the local building departments can be difficult to impossible.
And if the City get a burr in their saddle, they just refuse to pass your work.
I am hoping to learn more about the codes. As the more I read the codes, the more I realize local building inspectors here rarely follow the code.
Most of my houses precede modern building codes. I thought I read in several of the "existing building code" codes, that only what you are trying to fix is in scope for the permit. With few exceptions. Almost everything else is out of scope, except for those things that are clearly dangerous.
For instance, we know unreinforced masony is dangerous. But they city cannot force you to reinforce it to 2020 codes merely because you want to install a like roof, or replace existing windows with windows of the same size.
