It is state licensing law not local jurisdiction that determines when a licensed individual is required. The building code and the local jurisdictions do not have the authority to regulate the practice of engineering or architecture.What is the crush strength of the foam?
Is there a ICC. IAPMO or other approved report for that use?
Without a report, i would not even accept a RDP sealed drawing.
Many RDPs do not know what they are doing
Fair and good questions. I'll try to bring up the articles and see if that's addressed. iirc one was in northern MN, so no immediate termite threat.I'd be concerned with the EPS being in contact with the grade (R-318.4) because Virginia is in a moderate to heave termite infestation area, and Formosan termites are slowly making their way north. This might not be as much of a problem in upstate NY.
My other concern is how interior columns or bearing walls (if any) are supported.
Details such as in the OP generally specify that it be by direct bearing on the footing, not through the foam.My other concern is how interior columns or bearing walls (if any) are supported.
107.1 General. Submittal documents consisting of construction documents, statement of special inspections, geotechnical report and other data shall be submitted in two or more sets, or in a digital format where allowed by the building official, with each permit application. The construction documents shall be prepared by a registered design professional where required by the statutes of the jurisdiction in which the project is to be constructed. Where special conditions exist, the building official is authorized to require additional construction documents to be prepared by a registered design professional.
R106.1 Submittal documents. Submittal documents consisting of construction documents, and other data shall be submitted in two or more sets, or in a digital format where allowed by the building official, with each application for a permit. The construction documents shall be prepared by a registered design professional where required by the statutes of the jurisdiction in which the project is to be constructed. Where special conditions exist, the building official is authorized to require additional construction documents to be prepared by a registered design professional.
I Repeat: it is the state and not the local jurisdiction that has the authority to regulate engineering. So what the IBC says on this matter is wrong.IBC 107.1:
IRC 106.1:
For an unconventional floor system such as this proposal, if it's not prescriptively covered by the code and it doesn't have an ICC ESR approval report, I think the code official has sufficient authority under the code to ask for a registered design professional to explain why it's a good idea and how it's allowed under the code.
Some states, including Virginia, exempt residences and smaller, low hazard buildings from requiring design by an A/E.
Never thought of that being the reason....But it makes sense....If they waived engineering on use/ size, engineered stuff wouldn't be required to be....hunh....The 5,000 square foot exemption doesn't apply to engineers and engineering
I'm a little confused by this. Does this assume that the building is entirely built to the prescriptive requirements of (amended I presume) IRC? Hard to believe you would allow houses that utilize materials and methods not included in the IRC to be built without registered design professionals.Some states, including Virginia, exempt residences and smaller, low hazard buildings from requiring design by an A/E.
Yes, pretty much. Stuff like trusses, I-joists, and joist hangers are approved based on manufacturer's instructions, everything else is supposed to be prescriptive. If you want to go outside of prescriptive provisions, that's not a problem, but you will have to hire an engineer.I'm a little confused by this. Does this assume that the building is entirely built to the prescriptive requirements of (amended I presume) IRC?
I think most foams typically used under SOG would be more than adequate but there is also a product called Geofoam that would easily work and support a residential floor load:What is the crush strength of the foam?
www.geofoam.com
So, without the report, I would require the RDP, propose the alternate materials/methods. Without the report/manufacturer"s data, I would not allow it.I Repeat: it is the state and not the local jurisdiction that has the authority to regulate engineering. So what the IBC says on this matter is wrong.
The building department can only require what is required by the properly adopted laws. Since ICC ESR's are not formally adopted by a legislative body or an entity authorized to adopt regulations they cannot be required. This is not something that can be changed by a local ordinance. In this context ESR's are advisory. Are we a country of laws or is the building official an autocrat? Are there no limits on what the building official require?
Were the local jurisdiction to require compliance with ESR's they would create a monopoly in favor of ICC. The US Supreme Court in Parker v. Brown affirmed that only the State, and not local jurisdictions could create monopolies.
